PC will no longer turn on ** RMA update
21 Jan 2017
County Durham
Afternoon all
My PC decided to shut down randomly today, my daughter was playing some web browser game at the time and didn't quiet catch what it said other than the screen changed and it said something about power off and possibly safe mode.
Now it won't turn on at all. There is some power getting to the motherboard, the green light indicating the cpu is ready is lit. And the gpus power has lit up too.
Is it possible that a dead psu would still allow some power to these lights and that's likely the issue??
Anything I can do to test this. Unfortunately I don't have a spare psu lying around
Nothing loose loose. Tried ram in different slots, tried without gpu, reset cmos etc.
If the battery is dead would that stop it powering on?
A major hardware failure ( mobo/cpu/grxcard/psu) wouldn't show in windows with power off / safemode / reboot etc - it would just go off. Souns more like a corrupted OS or hard drive issue
Can you enter BIOS ? ( Spam DEL at boot up )
If not,
Remove hard drive - can you enter BIOS ?
No bios no. Its literally dead aside from the odd light. When I hit the power button it does absolutely nothing
Although i've never personally come across it, it does sounds like a partial failure in the PSU, maybe one of the voltage rails has failed or similar ( I'm no expert on PSUs' ).
Try the paperclip method on the psu, and connect 1 fan to it - that will show whether the 12v is working.
Tried the psu paperclip trick and nothing. Looks like it's dead, I'm just confused to why the cpu ready like and the gpu power lights come on
Those leds are possibly using the 3v or 5.5v rail of the psu, so low voltage going in, but dead 12v
OK thanks. The only thing that throws me now is the fact my daughter said it came up stating it was shutting now. Now I'm not 100% convinced this was the case as any issue with the psu I'm guessing it would just black screen. Also cpu issues such as overheating would normally blue screen.
Totally agree with you, a blue screen i could explain as a power drop causing instability then blue screen, or just complete black screen shut down.
I never encountered Windows politely saying it is shutting down, then find out the psu is dead.
Try disconnecting everything you dont need to boot. HDDs, fans (except CPU), maybe something is shorting out.
If you have a multimeter, you could do paperclip trick and check wires to see if they'll all giving desired voltages.
Also, check the power and/or reset buttons are not at fault. Disconnect them from the motherboard and just jump the pins manually to start. I've had faulty restart buttons before do similar things.
Tried disconnecting everything already but to no avail.
Mobo has a start button on there and I've been trying that, I was thinking the same regards the case power button, but still no luck.
Don't have a multi meter but did try the paper clip trick and nothing at all.
I'm going to reach out to some friends to see if anyone has a spare powersupply I could try out. Unfortunately most of them are console players last time I checked
you could always buy one and use the 14 day return if it proves not to be the psu.
Little update. Was about to pull the Psu out for the RMA and decided to hit the power button.
It fired up straight away, error code 0d which if I remember correctly is a ram issue.
Anyways I reset cmos, updating the bios and left everything stock and so far its OK.
Really not sure what happened...
Thought I'd pop in with a quick update and some major praise for Seasonic
Throughout troubleshooting the shutting down issue I had a few back and forth's with Seasonic over email, with the Computer sometimes working for a few hours before shutting off, then other times wouldn't turn on at all I wanted to ensure they where aware. Last thing I wanted was for it to be returned and it work first time and they just ship it back.
During the emails Seasonic where great, informed me of different test to do, including running stress tests to test other components, those had already been done but if this was someone less tech savvy its great to see that they put this kind of effort in.
Once I had confirmed that all tests had been complete but that due to the PC sometimes working I couldn't be 100% sure the PSU was at fault, they still suggested I send this in the they would send a replacement.
Sure enough within a week of posting I received a brand new 750w Plat rated replacement, PC has now been running since yesterday with zero issues.
Hats off to Seasonic, brilliant RMA service!
Sounds like you have a failing startup capacitor.
Once the PSU is running it will run perfectly. Your daughter could be correct, it did a restart but the PSU couldn't power on again.
Randomly it will startup when you push the button. Once it's on it will be fine.
Return it, it'll happen again.
Think you missed his update post below the one you quoted
sounds like a similar issue to what i had, mine was a psu issue.
it worked fine but would cut off randomly, sometimes after weeks or days.
but it wouldnt turn back on unless i left it for some time.
swapped psu and was ok, so had to buy a new one as seasonic psu was out of warranty.
