rofls you are correct. I finally did watch the video a week or two ago and I went out and bough them. Time for not only one, but two posts of results!
So the fan bracket,5 pack of Arctic P12s, and gpu-mini adapter cable, came in from Amazon and I was able to assemble the fan bracket. Only 2 fans are needed, so 3 are being put up for sale. I assembled everything and closed up the pc case and my temps were extraordinary high. After some research, apparently, little did I know, that gpu fans don't pull hot air from the heatsink, they actually push cool air. So yeah, I had the fan orientation wrong. Oops.
Try #2: After taking apart everything and putting the fans in the correct way (fan grill faces heatsink, open fans face bottom of pc case), I actually really like it. They plug in straight to the GPU. These 2 fans are extraordinary quiet, and it took 2-3 hours of COD before I could hear anything from my pc. Even then, I had to put my ears up against it. This is with my headphones being off and my ceiling fan being off, all to reduce extraneous noise. Whats best is that this solution doesn't void my wtty, is very easy to do, and can be used for all future GPUs. Even if future GPUs have a massive 3 slot heatsink, I still have 2 slots extra, so I can just place it down one. Of course, the GPU (2 slots) and fan bracket (2 slots) now take up 4 slots, but I never had anything there, so that's fine with me. The OEM sapphire fan shroud, screws, and slot insert will go into a ziplock bag and stored in my generic pc parts box for RMA, or years down the line I want to sell this.
Quite happy, I now have a 99% dead silent pc under full load. Temps/noise will only get better when I delid the 6700k in a few weeks. Maybe i'll put the LM on the gpu too.
Stats during COD sessions:
90% PWM: 66C, 76C
70% PWM: 69C, 78C
50% PWM: 73C, 83C
45% PWM: 76C, 85C
40% PWM: 80C, 90C
