Antec P120 Build - RGB is king!
8 Sep 2003
150 yds from OcUK
Hey guys.
Check out my new build.
Hardware:
  • Antec P120 Crystal Case
  • AMD 3900X
  • Z570 Asrock Steel Legend motherboard
  • GTX 1080 Ti
  • 16GB G Skill RAM
  • 512GB ADATA 8200 NVME
  • 2TB Samsung Evo 850
  • 1TB Samsung Evo 850
  • Alphacool liquid cooling parts
  • Antec ARGB Prizm Fans x 6
I etched the Antec logo into the side door glass.
22 Apr 2008
Bryn Celyn Wales
Looks fantastic mate, well done, lovely that is. What colour you staying with? I like the pinky purple myself, also, yeah how'd you etch the tempered glass?
Also, I was gonna go with those antec fans, they nice and quiet?
13 Sep 2015
The etching was done using a template i made using etching cream. Its quite simple to be honest.
Check online for " Armour Etch - Glass Etching Cream 80 grams."
Good to know it's not too difficult. How world you describe the finish? Is it quite even, or does the opacity vary?
16 Sep 2010
Nottinghamshire
@Ace Modder Nice build that! are they antec rgb prism fans? they look like it ... which controller do you have? I have the same fans and wanting to change the colours etc RGB lights are all new to me! at the moment I have RGB cooler,ram,gpu,fans,motherboard all different colours haha
OP
8 Sep 2003
150 yds from OcUK
They are Antec Prizm fans and I am using the includes Hubs, each hub supports 5 devices, I have 6 fans and 1 RGB Strip (which is part of one of the prizm kits)
I daisy chained the hubs together and synced via motherboard for motherboard software control.
You realise the included hub has a button to change the colour modes? Or you can connect to motherbaord to control RGB modes via software (as long as you have a RGB motherboard)
16 Sep 2010
Nottinghamshire
I only got the 3 pack of fans from antec mate so i need a hub then will any hub do or does it have to be antec? I bet you can't buy these on there own :(
OP
8 Sep 2003
150 yds from OcUK
The 3 pack and 2 LED strips kit includes the hub controller. Check the box.
We only have 3 different SKUs for the 120mm Prizm fan.
EDIT:
After a quick google, did you buy a 3 pack of fans from Amazon? Spark series?
The spark is our RGB fan, not ARGB and we sell these fans as single units only, without a hub, however I have found a weird 3rd party seller from Taiwan selling a 3 pack of spark fans without a hub controller. I hate Amazon, they are not part of Antec company at all, and they have bundled their own 3 pack which doesn't support our hub controller, they are designed to be daisy chained together and connected to a RGB motherboard header only, which is because they are RGB, not ARGB. at least the listing says it doesn't support our ARGB hub.
This 3rd party seller has called themselves, Antec Direct EU, but it is not Antec at all.
16 Sep 2010
Nottinghamshire
EDIT:
yep that’s who I bought them from there 3 pack from that seller. So I have no way of controlling the colours then damnnn
