- 26 Sep 2017
- In the Masonic Temple
If there is an 8 core ccx, does that mean the 8 core chip doesn't need infinty fabric?
Still needs it to connect to IO die. But not for communication between coresIf there is an 8 core ccx, does that mean the 8 core chip doesn't need infinty fabric?
Still gotta talk to the I/O die and other chiplets. All 8 cores in a chiplet now have access to each other directly rather than 1 pair of 4 jumping through the I/O die to get at the other pair.If there is an 8 core ccx, does that mean the 8 core chip doesn't need infinty fabric?
AMD Ryzen 9 4950X Will Have a Boost Clock Higher than 4.8GHz, Per Core Voltage Adjustments
I guess it will help all-core overclock. Or per-CCX overclock.https://www.hardwaretimes.com/amd-r...her-than-4-8ghz-per-core-voltage-adjustments/
"Per Core Voltage Adjustments" hhmmmm....
Really? It'll fkn crush it, mate.If AMD can manage a 5GHz boost for its top-end Vermeer part, it’ll come very close to beating Intel in gaming workloads as well.
Give more juice to crappy cores. Or lower clock and voltage to crappy CCX
From that article
Then they shouldn't be peddling their wares, or at the very least refrain from making technical statements.You can't expect too much from these tech journalists, they are not analysts...
Then they shouldn't be peddling their wares.
You can't expect too much from these tech journalists, they are not analysts, the characteristics difference in Multi vs Single CCX is not something that has registered with them, to this day only Steve Burke and Steve from Hardware Unboxed have realized this.... the rest are completely ignorant to it.
So true! I was very involved with PC hardware around 1998-2008. Had a break focusing on work/PhD/children, now looking to get back into it and struggling to find the detailed analysis that was available back then. All seems to be pretty shallow You Tube video.Yeah, the quality of tech journalism has fallen off a cliff in the last 10 years.
Not if their benchmarks show otherwise, unless they change their games to favour Intel. But then that's bias, not ignorance.I'll also bet they will still claim that Intel is still the gaming king.
Military design? You're still behind the curve, military has been and gone, except for the UTTER LIE that are contemporary Asus TUF products. Oh, and MSI naming their stuff after weapons I guess. I'd kill for some industrial design thoughAnd what on earth is going on with motherboard appearance? Why all this naff military / industrial design. Some boards even come with stickers!! Are they marketing to 8 year olds?
Hopefully that will mean a working per core overclock next time round.https://www.hardwaretimes.com/amd-r...her-than-4-8ghz-per-core-voltage-adjustments/
You kids and your hip-hop lingo....Some boards do look the absolute sex though...
Yes it seems they are marketed for 8 year olds but don't worry you can have loads of RGBSo true! I was very involved with PC hardware around 1998-2008. Had a break focusing on work/PhD/children, now looking to get back into it and struggling to find the detailed analysis that was available back then. All seems to be pretty shallow You Tube video.
