- 13 Dec 2006
Does another positive test result reset his quarantine clock back to 7/10 days?
Are we just going to keep on using this thread? I mean it is the same race essentially
Watching Ch4 last week and you really see how absurd his screaming and constant stream of BS truly is.Crofty: "The first and probably only 70th Anniversary GP..." well, yes. That's how anniversaries work you absolute walnut.
I must be one of the few that doesn't mind Crofty. Though I did enjoy watching the C4 product last week.
DC, Brundle and Jake Humphrey was probably my favourite F1 presenting team in a while. If we could've had them with Webber, Karun and Ant I'd be pretty chuffed.
I think a new thread is better. Otherwise the conversations get muddled and we can't have a poll![]()
Turns out RP’s Pink Mercedes copy actually has real Mercedes parts which should be RP’s own designs and Renault’s protest just got upheld.
https://www.bbc.co.uk/sport/formula1/53693249Although the design process has been declared illegal, the stewards ruled that Racing Point are able to run the brake ducts for the rest of this season.
The penalty "covers the entire process of (non)-designing of the brake ducts and making them available for use during the whole 2020 season", even though their use "remains an infringement" of the regulations. The points deduction and fine are considered to be a sufficient punishment for the offence.
That is not correct, RP got the design from Merc last year when permitted, in 2019. They used the front ducts so could again use them this year, they didn't run the rears last year but fitted them to this years car, therefore making them essentially illegal.Turns out RP’s Pink Mercedes copy actually has real Mercedes parts which should be RP’s own designs and Renault’s protest just got upheld.
It’s got to the stage where his voice is echoing off the walls when he’s shouting. “Omgwtfbbq someone ran wide at turn 1!!!”
