As consoles are so well optimised, the system/OS doesn't use that much, and the majority can be dedicated to the GPU as VRAM. The next gen of consoles have 16GB of shared memory...
Expect AAA games 'ported' from PS5/Next gen Xbox to effectively double in VRAM requirements verses what we see now. This is planned obsolescence, as current 8GB VRAM cards will not be able to run equivalent graphics settings as the new consoles due to this VRAM limitation.
Nvidia will make a killing.
They also have to run the entire system with that same 16gb.
The Xbox series x for example has 10gb fast and 6gb slow memory. While it all could be used you would see a fairly big difference in terms of performance dropping 40-50% in memory speed mid game.
The ps5 has access to nearly all memory I think around 13-14gb, but is obviously not as quick in the specs department with 2070ish levels of performance most likely.
I’d imagine the next line of GPUs will be packing 12-16gb IMO. 8gb is starting to become lacking especially if next gen say a 3060/3070 matches a 2080Ti, I don’t think 8gb will be enough.
