- 1 Mar 2008
- Near Longleat, Raaaar!!
Hi all, wasn't sure whether this was a motherboard or case question so put it in here instead.
I currently have a mATX board in PC-o11 dynamic and have seen a great deal on a EATX board which I'm keen on.
I currently have a 360 rad mounted in the tray and am concerned given the extra width that it won't fit. Or if it does, it won't then have clearance behind to get the cables through.
Google is light on images or info so thought I'd check with you clever lot and see if anyone is or has done this?
Pic below shows the rad and the current clearance. I believe E-ATX is just over 3 in wider...
