Noblechair Hero - Black Edition CLEANING
16 Dec 2009
Belfast
I was going to purchase the noblechair cleaning kit but its not available anywhere apart from a German shop that doesn't deliver to the UK, so does anyone know what would be best to use to keep my new chair clean and in great condition?
I would appreciate any input plz, thanks.
Man of Honour
13 Oct 2006
I would try to avoid liquids as much as possible TBH - it just seems to expedite cracking on these kind of chairs no matter the brand or material :(
Might be worth looking at some Autoglym products.
OP
16 Dec 2009
Belfast
I was thinking about that kind of stuff but wasnt sure, was hoping maybe someone else has tried something they would recommend
Man of Honour
13 Oct 2006
My dad (used to run the R&D at Pittards) reckons people over-think it and unless the coating is compromised doing anything other than cleaning with a mild but good quality detergent and a couple of microfibre cloths is a waste of time.
OP
16 Dec 2009
Belfast
I have used a baby wipe on the underside of it for testing and works really well, so until i can get my hands on the noblechair stuff will use a baby wipe when needed.
29 May 2012
Dorset
Can recommend renapur leather balm can be had off ebay with applicators for the price of a few pints but if used sparingly as suggested will last you years . Waterproofs, cleans and protects I use in on chairs, sofas, shoes, bike leathers all sorts and its never let me down
