Perfect, thanks.Google MSMG ToolKit. I can't provide a link, as OcUK frown upon the forum. That'll do everything you want and then some.
So how come the size of my original ISO image is reduced after building my new customised ISO? Surely if it was hidden, the file size would barely change, if at all. I'm not talking about a reduction of a few MB either, as I see a reduction of over 1 GB and that's with the updates integrated.Doesn't remove bloatware, only hides it, therefore, pointless.
Whereabouts is that mentioned, I don't see it so am probably looking in the wrong place. Just quoting the text will perhaps enable to find it myself. But I do remove the apps from an offline image.You know how compressed files and installers work in Windows right? A 100Mb installer could well be a 500Mb application once installed. It's the same here, you've removed the full fat application, but the installer and it's capability to be installed remains, hell, the site you refer to even states that.
The ONLY way to permanently remove the application, it's installer stub, and ensure it never comes back, or be sideloaded by a feature update is to remove it from an offline WIM. The key difference is this. One way removes the apps, but easily allows them to return, the other borks your start menu, but gives you 100% piece of mind (and visual confirmation) that the apps have gone for good.
This is from a 2004 image with the latest Cumulative Update installed on virtual machine:Do you still have a Windows Apps folder at %localappdata%\Microsoft\WindowsApps folder? If so, what's in there?
Essentially your reduced file size is due to the way UWP apps work and Microsoft's unbelievable exploitable approach, using SquirelTemp to install them. On a online image, the app executable remains, which means, at any time (and they do) MS can replace, update, re-install those built in apps, if required or not. One case in point is, the XBOXTcui app is required for feature updates. If it's removed from an offline WIM, Windows won't update beyond 1809. If it's removed from an online image, WU will simply reinstall the file from the stub installer and may pull the relevant files from the internet if needed, hence your reduced WIM file size.
Removing them will of course show them removed from a PS command, but believe me, they are very much still there unless removed from an offline image.
Where do I get that from?Install the LTSB or LTSC version
That doesn't come with the bloatware. MS doesn't like home users installing it, because they want to spy on you. But **** Microsoft.
grab a compact build from TeamOS.
 and definitely don't do this. Lesson 1, the clean source principle. If you didn't create the WIM, you have no idea what's on it.This a millions times over.and definitely don't do this. Lesson 1, the clean source principle. If you didn't create the WIM, you have no idea what's on it.
This 4 million times overThis a millions times over.
There is no straight answer to remove bloatware in windows 10.
