- 1 Jul 2003
- There's a voice that keeps on calling me.
Hi Folks,
Just wanting to pick electricians brain.
I’m having a PHEV delivered in a few months. I was going to get a charge point fitted via the OLEV scheme, but the prices are mad, around 800 after the grant for a very straightforward install with budget charge point.
So the plan is to self source the EV point, do the donkey work of wiring and mounting the EV point and CU and then get a sparky in to do the final fix and certification and DNO notification.
I will be running a 6mm armoured cable from a separate CU for the point, but I was thinking if I could I wire in a external socket on the same SWA cable. I’ve always wanted a point outside for the jet wash etc, but I wasn’t sure if I could use the same cable as the EV point.
Cheers for any advice.
