Digging a drive way - found this in my lawn, what is it?
Caporegime
18 Oct 2002
block 16, cell 12
so I'm digging the front lawn down to 200mm and found this in the middle, any ideas what is is or what its for?
Am I okay to remove the big stone slab at the top and cover the hole to lay limestone foundation?
There is a hole but it looks sealed off at the bottom?
There was a lawn over it but lawn is now removed!
Thanks
Thanks all,I was hoping tto find the treasure if the knights templar down there!
So if I put a cast iron grid over the top of the hole and then cover with 40mm limestone water should still be a to get through right?
You need a staff, six Kadams high also the headpiece of the Staff of Ra. Place arrangement in the hole waiting for the sun to rise and bingo found yourself the well of souls.
Hm interesting do you think we need to keep access to it? That would be a pita to build into the surface if the drive. My plumber mate is round on Thursday he's going to check it out.
Thanks for the help.
What's at the bottom? do have a stop **** elsewhere?
