Intel Claims Its Cheaper To Build A Faster Gaming PC With Its 10th Gen Core CPUs Than AMD Ryzen 3000
6 Oct 2007
North West
Somebodies DIY sales are in the dumpster.
https://wccftech.com/intel-claims-1...e-and-faster-than-amd-ryzen-3000xt-in-gaming/
The performance benchmarks show that the Intel Core i7-10700K outperformed the AMD Ryzen 9 3900XT in several AAA titles. The Intel CPU was up to
  • 23% faster in Total War: Warhammer 2
  • 17% faster in Leauge of Legends
  • 15% faster in Monster Hunter World: Iceborne
  • 14% faster in Rocket Leauge
  • 12% faster in War Thunder Tank Battle
  • 6% faster in Total War Three Kingdoms
14 Sep 2009
Northumberland
I'm surprised that they've chosen to use a lower RAM speed on their own system. I'd assume a higher speed would have given better average results for their benchmarking.
Man of Honour
13 Oct 2006
I've not kept up with the situation on the 10K series side but generally Intel hasn't needed as high RAM speed - due to the architecture on AMD's side there is a big increase in performance upto around 3000-3200MHz - Intel could have stuck them both on slower RAM to spoil the AMD performance results but then I guess it would struggle with the cost narrative.
6 Aug 2010
Birmingham
Intel pushing the one main advantage they have, I am shocked! SHOCKED!
Not to mention that it's skewed by using a Ryzen 9 that has 4C/8T over the 10700K. A Ryzen 7 would make a more fair comparison but when has fair ever made good marketing.
27 Nov 2006
Coventry
Performance results based a 1080p who buys a 2080ti for that ?
Would the % difference be the same with diffrent gpu's.
Any higher resolution then it's not the CPU bottlenecking, it's the GPU. And so all the results would be the same.
Therefore, you don't need that good of a CPU anyway. Because it's always going to be the GPU that is the limiting factor.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
I'm surprised they went for the 10700K. I bet the 10600K would still be as fast, or there abouts for even less money.
Same with the 3600 vs the 3900XT.......
They also cherry-picked the games that give them the best margins, and still only managed 15%. In those games a 3300X would probably do better.
Whats fascinating is that Intel are now shouting about being the budget option, how times change.... :D
Caporegime
1 Jun 2006
Notts
Oh dear me.
whats wrong intel is quicker. no debate they are at games currently. current amd cpus are the same as a 8700. non k. they two gens behind on games. the new ones should be about level or just in front.
before people try to debate that AMD are as quick..AMD used them being as fast as a 8700 non k in there press launch....:p
so intel are faster at games currently and there is no debate.
Caporegime
17 Mar 2012
Well, they used AMD's second most expensive CPU vs a lower end Intel CPU to claim the "Budget choice" a more suitable CPU to compare to the 10700K is a 3700X.
You don't need 12 cores 24 threads for games. Well there are one or two that will help but Intel are not using those games because they get curb stomped in them.
