I like the fact The NZXT H210 had a psu shroud and can take an atx psu , check size limitations.
The Coolermaster NR200 i like the vented side case and seems to have more watercooling options.
Depends what options you need
What's your opinion ?
When you say watercool do you mean a custom loop or aio cooler ?Good question, I like both aesthetically. I'm not yet sure if I'm going to air or watercool the new build, I may start with air and then upgrade down the line so having the option of decent watercooling is a plus.
Think you can fit a 240mm in both just check the positioninmng, think it's at the front for theIt would be an aio cooler for sure.
Nxzt and top and front for the cooler master.
NR200 Owner's ThreadI'm reading so many good things about both cases. It's a nice predicament to have really as they are both looking like solid choices!
I'm pretty sure the Cooler Master case has only just launched, and it sold out currently. I think I'm leaning towards this one. Does anyone have it yet and want's to showcase their build?
CoolSome decent builds on here. Pretty set on this now.
Cool
Have you got a parts list yet ? And or intel.
Good choice .I'm planning on going AMD for this build.
Rough idea is:
AMD Ryzen 7 3700X
B550 or X570
Sapphire Radeon RX 5700 XT NITRO +
Will add one or two large M.2 NVME SSD's, 32GB RAM and a decent PSU.
Thanks!
OK cool, I will check them out!
Check case limitations on parts , don't wanna buy something that don't fit.
PSU Support - SFX, SFX-L .
You can run a 280 rad in the H210. I'd use a SFX PSU in the H210 as well as this gives extra space through the shroud for the GPU to pull air.
Here's one of my previous builds.
