Man of Honour
- 21 Nov 2004
Bars are like gold dust, especially at that price. They’ll be gone. They arrive well packed.
I'd buy the bar now, it comes well packaged so you can just store it.
Part of a group on facebook and there all raving about a company called muscle squad who have stock of weights and bars. Terrible name mind you!
https://musclesquad.com/collections/all/products/musclesquad-6ft-olympic-barbell
Get a stock of extra blades - you'll go through a few cutting that many 18mm mats.Trying to work out mats, thinking I will get the 18mm thick version of these: https://www.arkmat.co.uk/gym-mats/easy-clean-gym-flooring-mats/easy-clean-gym-flooring-mats.html
Presume I can cut them with a decent stanley and a piece of timber to prop the edge up on? Will just have to be careful with the measurements as I'd like them to butt up to the walls as tightly as possible
6ft and 15kg aren't worth it.
Wanted a 6ft to save space, why not worth it?6ft and 15kg aren't worth it.
I've got the 12mm smooth mats and just cutting a bit off a small edge section blunted a blade.
https://www.arkmat.co.uk/gym-mats/1...gym-mat/12mm-smooth-black-rubber-gym-mat.html
Sounds like you've got the technique down though - all the US redditors say to prop the mats on something to allow the weight of the mat to help with pulling the cut open.
Are the 12mm thick enough? They're obviously a bit cheaper and I don't plan on doing any extreme powerlifting drops onto the floor... but felt like thicker would be worth it?
You've got a pretty well organised setup. If I could source a bunch of pancake 5kg standard plates and some wall storage I suspect I'd be satisfied with the lat/low row.For all shoulder and arm cable work I have hex plate 10s, 5s, 2.5s which are super quick to add/remove, especially with the handle. They are placed next to the cable machine for quick access. They have the added benefit of being used on my various oly bars as well.
https://mirafit.co.uk/mirafit-hex-olympic-weight-plates.html
When I do seated rows, I switch to using my bumpers, but I don't do any drop/super sets.
You can see the plates here in my gym.
You'll either have issues with it in the rack (too short) or they cannot hold enough weight due to smaller sleeves.
For me , yes. I'm lifting in my garage with a concrete floor. Silly as it may sound I was also concerned the extra 6mm would interfere with headroom for the rack if I went with 18mm.Are the 12mm thick enough? They're obviously a bit cheaper and I don't plan on doing any extreme powerlifting drops onto the floor... but felt like thicker would be worth it?
ha, i was measuring the bar length vs width of the rack oops! rather than length of the middle bit, cage is 123cm wide.
You can get rack-friendly 6ft bars - usually called 6ft International Olympic bar. I've got one from fitness superstore. It was cheap (pretty sure I paid £70-odd at the time) but I'm only using it for benching and it's fine.ha, i was measuring the bar length vs width of the rack oops! rather than length of the middle bit, cage is 123cm wide.
I'm a bit restricted on space - my plates and dumbbells are all on the floor at the moment. I'm trying to work out some storage but space is a premium. I'll get some pics up of my dungeon!
