120ºc seems hot for the normal operating temperature of oil. It's usually around 90ºc
I agree. Engine designs have margins though to help mitigate against idiots giving beans without properly warming up and also 45 year old Susan who does not change the engine oil because it is a 'waste of money'.Mine takes at least another couple of minutes for the oil temperature to get to 50C after the water has hit 90C Modern cars have very thin water jackets and give a false sense of engine temperature.
Diesesels need load on the engine to even start warming up though. You are much better in starting it up and driving it.
.  The MX5 though I give some beans to when warmed up, albeit the temperature gauge is designed for the aforementioned 45 year old Susan i.e. it sits in the middle for a huge temperature range then suddenly swings to the right if the engine is about to blow up!What a waste of fuel
My car has an oil temperature gauge not a coolant temperature gauge. I believe the same is true of virtually all BMW models introduced in the last 10 years.
In all other cars I've driven the operating temperature was between 80-90°C. In my Z4 however the 'middle' is 120°C. If you are not pushing it it will only go up to 110°C and stay there. Once you start revving it a bit more it will go to 120°C, but drop down quickly to 110°C once you lay off the revs.
Engine is N54, 3.0l straight 6. Not sure on oil grade if I'm honest.Interesting.
Out of interest, what engine is it and what's the recommended oil grade?
That's just due to it being a dieselDrive an auto diesel so let the electronics handle it. I can't remember the revs ever getting over about 3500 even when I do put the foot down. Also, it would take 5-10 minutes to get anywhere I can do over 40 mph without attracting the attention of gentlemen with blue flashing lights.
. Is there much point redlining diesels anyway, isnt the most optimum power at low revs not high?That's just due to it being a diesel. Is there much point redlining diesels anyway, isnt the most optimum power at low revs not high?
 I'm usually limited to 2-2.5K until it has warmed up (which is a lot on a 3L V6 with 550nm torque) - but if I go into kick down it will exceed that even cold - potentially putting it into limp mode on a steep hill :sIf you want to rag a diesel you want to change gear so that the RPM's drop to the bottom of the torque band. Its usually not worth redlining them unless they have an upgraded turbo.
wikipedia said:The V9X V6 diesel engine develops 170 kW (231 PS; 228 hp) and 550 N⋅m (406 lb⋅ft) of torque. Peak torque is achieved from as low as 1,750 rpm to 2,500 rpm, with 500 N⋅m (369 lb⋅ft) available from 1,500 rpm. Idle speed is 650 rpm.
What if your torque band is basically the whole range!![]()
your mileage may vary.
 does OK if you drive sensibly but heavy foot and you can literally watch the fuel gauge move.Or not very much at all on mine if you rag itdoes OK if you drive sensibly but heavy foot and you can literally watch the fuel gauge move.
In the works van however... that'll get ragged foot to the floor within 20 seconds of being started
If you only have a water temp gauge and don't have an oil temp gauge, the rule of thumb that I've always worked to and find is accurate is that it takes approximately 2.5-3 times longer for the engine oil to reach operating temp than the water
