How long do you let your engine warm up for?
I already driven my car all the way from home to work before my engine even completely warmed up :p:p:p
My drive to work is only about 2 miles (6 minutes)
120ºc seems hot for the normal operating temperature of oil. It's usually around 90ºc
In all other cars I've driven the operating temperature was between 80-90°C. In my Z4 however the 'middle' is 120°C. If you are not pushing it it will only go up to 110°C and stay there. Once you start revving it a bit more it will go to 120°C, but drop down quickly to 110°C once you lay off the revs.
Mine takes at least another couple of minutes for the oil temperature to get to 50C after the water has hit 90C Modern cars have very thin water jackets and give a false sense of engine temperature.
Diesesels need load on the engine to even start warming up though. You are much better in starting it up and driving it.
I agree. Engine designs have margins though to help mitigate against idiots giving beans without properly warming up and also 45 year old Susan who does not change the engine oil because it is a 'waste of money'.
I don't think I have ever thrashed the diesel Astra :p. The MX5 though I give some beans to when warmed up, albeit the temperature gauge is designed for the aforementioned 45 year old Susan i.e. it sits in the middle for a huge temperature range then suddenly swings to the right if the engine is about to blow up!
In terms of taking it near/to the red line I'll try and give it closer to ten miles unless I get in a very rare situation where it warrants the need to use the full rev range sooner. My commute is 25 miles each way, so plenty of time to let it warm up and then exercise it. Looks like a lot of people might say ten miles is excessive, but its an old car with 177K on it so most of the time I treat it to a more sedate life these days and maybe give it a decent blast towards the end of the commute two or three times a week to keep the cobwebs out. Then it gets a brief chance cool down before being switched off, mainly because of the turbo.
My car has an oil temperature gauge not a coolant temperature gauge. I believe the same is true of virtually all BMW models introduced in the last 10 years.
An interesting tidbit. Not sure doing away with the coolant temp gauge was the right call though. Though I guess it will just flash up a message instead if coolant temp gets too high.
Interesting.
Out of interest, what engine is it and what's the recommended oil grade?
I keep mine below around 3-3.5k rpm for the first few minutes, and won't give it the full beans for a good 10 minutes at least of steady driving.
Usually takes a good 10-15 mins for engine & transmission temps to get to green on the gauges.
Keep it below 2k revs till then.
Having said that, most of my journeys are commuting and they are only 20 min journeys, so on the road I hardly ever go above about 3k to 4k revs (redline 7.5) but then 3k in 10th is damn near 100mph :p:p
Drive an auto diesel so let the electronics handle it. I can't remember the revs ever getting over about 3500 even when I do put the foot down. Also, it would take 5-10 minutes to get anywhere I can do over 40 mph without attracting the attention of gentlemen with blue flashing lights.
That's just due to it being a diesel:D. Is there much point redlining diesels anyway, isnt the most optimum power at low revs not high?
If you want to rag a diesel you want to change gear so that the RPM's drop to the bottom of the torque band. Its usually not worth redlining them unless they have an upgraded turbo.
There is only so far the electronics handle it in my auto :o I'm usually limited to 2-2.5K until it has warmed up (which is a lot on a 3L V6 with 550nm torque) - but if I go into kick down it will exceed that even cold - potentially putting it into limp mode on a steep hill :s
I tend to go easy on my car for the first few miles although I don’t let it idle when I first starting, I get in and go, just as the owner’s manual advises...
With the truck which takes a good few miles to make the temperature gauge start to move it has to deliver pretty much full power as soon as I’m leaving the yard - if I’m at full weight - as there’s a steep hill to climb within 1/4 mile of our depot.
It’s largely pointless to idle to “warm up” especially with a diesel, I’ve noticed if I’ve stopped and left the engine running for a while (say 15 minutes or so) the gauge will drop from the middle down into the blue as the engine cools, the owners handbook for the truck specifically advises against idling for any length of time with a cold engine.
What if your torque band is basically the whole range! :p
wikipedia said:
The V9X V6 diesel engine develops 170 kW (231 PS; 228 hp) and 550 N⋅m (406 lb⋅ft) of torque. Peak torque is achieved from as low as 1,750 rpm to 2,500 rpm, with 500 N⋅m (369 lb⋅ft) available from 1,500 rpm. Idle speed is 650 rpm.
Mine idles at 750 (not sure if it is a typo on wiki). A little turbo lag aside I just love this thing - I've driven much faster vehicles but the way it puts the torque down is so **** satisfying.
Can't answer, your mileage may vary. :p
I know on more modern diesels with an efficient hybrid turbo, you can pretty much use the whole RPM range like you can in a petrol. And in an old diesel with a giant turbo you should probably change gear at the reline.
My only experiences have been in VW's. A 1.9TDI VE 90, a 1.9TDI PD115, a 1.9TDI PD130, and a 2.0TDI 140 with a remap to about 180 on the standard turbo.
In the 1.9TDI's there was basically no point redlining it.
I tend to leave it a good 10 minutes usually, non of our current cars have an oil temp gauge but when i fitted one to my Subaru it was amazing how long it took to warm compared to the coolant.
In the works van however... that'll get ragged foot to the floor within 20 seconds of being started :p
I'm not sure if related but possibly why we have a relatively high EGR failure rate for our work vans :s though strangely pretty rare to have DPF or turbo issues.
If you only have a water temp gauge and don't have an oil temp gauge, the rule of thumb that I've always worked to and find is accurate is that it takes approximately 2.5-3 times longer for the engine oil to reach operating temp than the water
Would a good multigrade oil of the correct spec not be doing a good job from the get go?
