MSI RTX 2080S Ventus XS OC Waterblock
RCM
RCM
3 Dec 2019
Anyone know of a waterblock that will fit this card? Apparently the XC version is a non standard 2080S PCB so most, if not all, blocks won't fit.
Bitspower make one but there appears to be no stock in Europe and it's silly expensive (€200) when available.
I looked into this as i had the MSI Gaming X Duo card which is very similar to your ventus but with no avail. Ended up selling it and getting a 2080 Aorus xtreme Waterblock edition for around the same price.
Yeah, it's a shame this card doesn't seem to have anything fit apart from the Bitspower block, and that will be $250+ from the USA. Was hoping there's another block out there that correctly fits unofficially.
If I can't find a compatible block, I'll possibly get a 3000 series card next year and make sure it's a standard PCB before buying.
