Can you measure the current drawn from the battery? You might need 4 hands to hold the multimeter probes and a bit of wire to measure it. The battery is only used for the clock and NVRAM, which only need a few µA, but if it's draining in mere days then the current might be 0.1mA or more, which should be measurable on a standard multimeter.
