Both feature in GamersNexus Arctic liquid Freezer review. Basically equivalent, AIO is slightly ahead
You won’t regret it, using the 360 version on my 3950X. Very quiet, even at max RPM.Cheers, I did give that a watch. I will give the Arctic Liquid freezer II a try.
I got the 360, installed and in the low thirties idle. Forgot to look while gamingAs you say it is almost silent, very happy with it so far(with the benefit of the VRM fan).
I've had both the 360 and 280, plus also have the D15. The D15 is a bit quieter but the Arctics cool a little better. The 280 cooled better than the 360 in my case so I went with that.I got the 360, installed and in the low thirties idle. Forgot to look while gamingAs you say it is almost silent, very happy with it so far(with the benefit of the VRM fan).
