Maths Problem Help
6 Feb 2003
Sutton
GPfVh1R
Having a problem solving this, I can do basic algebra but stumped with this one. Any help appreciated.
https://ibb.co/GPfVh1R
Caporegime
20 Jan 2005
Co Durham
from the scond line
2h = 142-t-s
from the third
2s= 154-2h
Therefore
h + t + 2s becomes h + t + (154-2h) which becomes h + t + 154 - (142-t-s) which becomes h + 2t + s +12
You know h + 2t + s = 99 therefore the answer is 99+12 = 111
17 Oct 2009
You know 2h + 2s = 154 so halving it all
h+s = 77
Taking
h+ 2t+ s = 99 and subbing in h+s = 77 you get
2t+77=99
2t= 99-77
so 2t = 22
triangle = 11
Taking 2h + t + s = 142, subbing in t=11 and h+s = 77 you get
h+77+11 = 142
h = 142 - 77 - 11
heart = 54
h+s=77, subbing in h = 54
54 + s = 77
s = 77 - 54
smiley = 23
so ? =2s + t + h = 46 +11 + 54 = 111
? = 111
Since @Greebo also got 111, I'll assume it's all correct :p
Wouldn't know where to start and not I feel dumb! :(
What level of maths is this these days? A-Level?
These days no idea, IIRC we were doing something similar probably between year 9 and year 11, thought that was ~15 years ago now!
2 May 2011
Woking
I did mine similarly to @loftie but not quite so efficiently
2h + 2s = 154
h + s = 77
2t + h + s = 99
2t + 77 = 99
2t = 22
t = 11
h + 2t + s = 99
h + 22 + s = 99
h + s = 77
h = 77 - s
2h + t + s = 142
2h + 11 + s = 142
2h + s = 131
2 (77 - s) + s = 131
-s = 131 - 154
s = 23
h + 2t + s = 99
h + 22 + 23 = 99
h = 99 - 22 - 23
h = 54
Therefore, 2s + t + h = x
46 + 11 + 54 = x
x = 111
I must admit, this took me longer than it should have because I made stupid little errors along the way.
17 Oct 2009
I think I started off by subbing h= 99 -2t - s or something similarly daft, then I realised that there was 2h + 2s = 154, face palmed and started there! Far easier :D
Edit : In hindsight, it probably would have been better for us lot to ask you how you'd approached it @aumz and give hints/help rather than just working it all out and showing you
2 May 2011
Woking
How else could we prove how good at basic maths we are if we don't answer for him?
14 Jun 2003
Whilst you can solve these types of problems by setting up a system of simultaneous equations, I don’t think that is the aim of them. I think they are probably more designed to do in your head rather than on a piece of paper.
In this one, you’ve already noticed that there are only 3 pieces of information since many of the rows and columns are duplicates. Let’s call them C1 =142 (column 1), C2 = 99 (column 2) and R3 = 154 (row 3). Notice that R3 has no triangles so we can only create the right number of triangles by using C1 and C2. We want to end up with 1 triangle, so start off with C2 - C1 which leaves us with 1 triangle, -1 hearts and 0 faces and that is equal to 99-142=-43. Now we have no faces, but we need 2 faces so let’s add R3 and we end up with 1 triangle, 1 heart and 2 faces = -43 + 154 = 111. Which is what we wanted.
Of course this is the same as solving the simultaneous equations but you can do it in your head without needing to use a load of algebra.
OP
6 Feb 2003
Sutton
No approach whatsoever as it just baffled me from the start.
19 Apr 2003
Year 6/7 depending on kids ability.
As mentioned - these type of questions are often used in 11+ exams.
Permabanned
22 Oct 2018
111, no need for algebra. Add up right column numbers = 451. Subtract bottom row total to give ?
Correct. Some folks are looking at the complicated way, but the total of the numbers on the right will equal the total of the numbers on the bottom, since both totals are just the summation of all the symbols. So take the total of the numbers on the right and subtract the total of the numbers on the bottom and BOOM! Five stars and a pass with honours for spotting that one.
11 Dec 2016
Oxford
there are 4 answers required, aren't there?
value of each of the symbols and the questionmark
Permabanned
22 Oct 2018
..and some folks aren't reading the question. LOL! But I still give extra points to bloodiedathame for working out the ? the simplest way.
