£100 more for a xx80 card than the 1080Ti was.The 3080 is looking not bad either, a nice boost over the 2080ti and if its around £800 would be what I'd be shooting for to upgrade my 1080ti![]()
Easily done, apology not requiredSorry, just woken up![]()
3070 = 2080Ti would be decent if pricing is good. At least its back to where we used to be rather than crappy 1 tier Turing.https://videocardz.com/newz/zotac-teases-upcoming-geforce-rtx-30-graphics-cards
(Rumour) only 35% faster
'Ladies and gentlemen, my names Paul'
Go to 4:26
Easily done, apology not required![]()
Are reference cards...sorry "founders".... cardsInteresting, as I may consider going direct with them also from release. It is either that or Zotac.
10GB of 19Gb/s GDDR6X though. You can't compare it to GDDR from 4 years ago!3080 only gets 10 GB VRAM, wow that's so poor for £800 in 2020. There's 4 years old cards, to be bought brand new today for well under £200 that have 8GB....
Yes. yes we do. Flight sim uses heaps for a start. Im not buying a top end card in 2020 (nearly 2021) that has less than 12GB. Sorry. If that means the 3080 is a no go then so be it. I'll wait for AMD. They are never shy with the amount of Mem you get.Do we actually need more VRAM?
Cant say I have ever checked how much VRAM I am using.
Yes. yes we do. Flight sim uses heaps for a start. Im not buying a card in 2020 (nearly 2021) that has less than 12GB. Sorry. If that means the 3080 is a no go then so be it. I'll wait for AMD. They are never shy with the amount of Mem you get.
Playing DCS VR last night and vram allocation was up to 10Gb out of 11 on my 1080ti - so I dont really want to downgrade vramDo we actually need more VRAM?![]()
would be prudent for them to do something. even if just a metophorical raised eyebrown or wink.Looks like it'll have to be the 3080 for me, unless I can make myself wait for the 3080S / Ti or AMD's offering.
I wonder if AMD will leak some info shortly after 1st Sep.
GeForce RTX 3090: 24GB, RTX 3080: 10GB
https://videocardz.com/newz/confirmed-nvidia-geforce-rtx-3090-has-24gb-memory-rtx-3080-gets-10gb
https://www.tweaktown.com/tweakipedia/89/much-vram-need-1080p-1440p-4k/index.htmlYes. yes we do. Flight sim uses heaps for a start. Im not buying a top end card in 2020 (nearly 2021) that has less than 12GB. Sorry. If that means the 3080 is a no go then so be it. I'll wait for AMD. They are never shy with the amount of Mem you get.
