- 2 May 2011
- Woking
Morning chaps,
So I'm running the following and (obviously) have been for a number of years without any major issues. I'm about to move it into a mini-ITX build, so as I'll have to get a new motherboard I need to consider what else might need upgrading.
CPU: Intel 2500K @ 4.4 GHz CPU
RAM: 16 GB DDR3 dual-channel @ 1600 Mhz
MB: Gigabyte Z77X-UD5H (soon to go)
GPU: MSI GeForce GTX 970 GAMING 4G (overclocked a bit, more when water cooled)
SSD 1: 120 GB (IIRC) Kingston thing
SSD 2: 240 GB (IIRC) OCZ Agility
My first inclination is to upgrade the CPU, but I did a little bit of digging last night and if I stick with the LGA1155 socket, I'm not really going to get much more power for my money. Nor am I sure that I need it as I really just use my PC for gaming.
I know I can't afford to upgrade the GPU, so that's staying.
I am finding my storage quite annoying. I might actually change to a large M.2 drive (maybe 1 TB) and stop running two SSDs. I was also running an HDD for a while which had loads of stuff on it, and that seems to have perished, so I'd quite like to replace that.
So, any thoughts?
EDIT: just seen that this might be better off in the Upgrade section. Could a mod move it please?
So, any thoughts?
