My 12 year old nephew seems to have broken his PC, he's taken it apart "to clean it" and now refuses to post, the codes on his MSI B350 Tomahawk indicates a dead CPU, I suspect however he's used too much force screwing the cpu cooler back down (he said he had to push quite hard!) and maybe broken the board.
The CPU and socket looks ok, no sign of bent pins etc, it just refuses to post, his GPU fans don't spin and it powers down immediately unless you hold the power button.
I've tested his GPU in my spare machine and its thankfully ok..
I'm minded to get this
**B Grade** Prime B350M-A AMD B350 (Socket AM4) DDR4 Micro ATX (MB-69L-AS) https://www.overclockers.co.uk/b-grade-asus-prime-b350m-a-amd-b350-socket-am4-ddr4-micro-atx-mb-69l-as-bg-935-as.html
or perhaps this...
https://www.overclockers.co.uk/asus...am4-ddr4-micro-atx-motherboard-mb-69q-as.html
My hope is he has damaged the board and this is a relitavely cheap fix.
Are these a suitable replacement? , should I be looking at something else instead (budget is limited, he's paying from pocket money savings)
Not very clued up on the AMD side of things I'm afraid, any help appreciated.
or perhaps this...
