What would be the best ones to go for? Maybe a founders in this case?The "tuf" cards are generally a bit ****.
I'm hoping my 3700x and PCI 3.0 X16 doesn't bottleneck it either
Me too - hello fellow Fallout fan! I have mine modded with a few 100 mods!
Ignore my comment, you are running 16.What would be the best ones to go for? Maybe a founders in this case?
Seen some posts on FB with people cashing in on their 2080ti trying to get above £600 and people are just offering low as £250, the seller is just getting advice to flog their cards at CEX while the asking price is still close to £500.
Wut? you don't play FPS at ten thousand FPS? Welcome to the club. Enjoy !
I don't get a constant 60FPS all the time,because I went a bit mad with the mods,and started making massive settlements. I actually need a CPU upgrade!
Gibbo is on his A game, he has no 2080S stock and hardly any 2080ti.
Yeah this is what I am wrestling with - sensible thing would be to buy 3080 then sell it on at small loss for the ti - but there is a lot faff involved with that and I imagine quite a few will do this upgrading from 1080ti/2080ti where ram is not quite there yet. Or just get the 3090 - probably gonna be 400 quid more than the ti but you can just sit on it after that and not worry.Hmm im torn.....3090 now? Or buy the 3080 for now and wait for the 3080ti...then sell the 3080...decisions.
£100 cheaper for such a monstrosity is fairer, £350 for AIB's seeing as they all look like crap.£100 more than FE for the MSI gaming X:
https://www.overclockers.co.uk/msi-...ddr6-pci-express-graphics-card-gx-36b-ms.html
I’m going for the 3090 future proof with 24 gig of ram an all seeing then 3080 in games has me set for it just hope my 1200 psu holds .
The one advantage 2080 Ti still has over the 3070 is (and also 11 GB) that it can be NVLinked, if you care about that. It's still an absolute beast of a card & for older titles it might be a better choice (eg 5K/8K nvlink for DX11 titles).
Best to wait for reviews and see what third party coolers can do performance wise vs FE.
Why does anybody buy Asus? I don't get it.
Only issue is don't the FE cards usually dry up fairly quickly, i.e. if you want one you need to get in fast?
If the 3080 Founders card's cooler works effectively, I like the look of it well enough that I probably wouldn't go AIB unless they were *cheaper* than the founders cards.
