NVIDIA ‘Ampere’ 8nm Graphics Cards
The things some people will accept to get a 3090 :p
don't just check length, you've got to consider the width and overall volume of the thing. It's no good cramming it into a tight slot but then finding it's messed up everything else around it by cutting off the flow to the rest of the innards. A handy guide on size requirements here:
Three unused expansion slots and 12.3" (313mm) x 5.4" (138mm) clearance for 3090 / Two unused expansion slots plus 11.2” (285mm) x 4.4” (112mm) clearance for 3080
I wasn’t really looking to upgrade from my 1080 this year and was going to get a ps5 but I’m really tempted by the 3080. Nvidia have done really well with the pricing on these which is making me consider this instead of the ps5.
Playstation 5 has the great exclusives that PC won't get.
Anybody else spot the ASUs strix is a dual bios card with an actual switch on the card with one bios marked performance and the other one is marked quiet?
these are going to be noisy and hot cards. Definitely sticking it under water as soon as I can
You 'don't feel guilty', but you willingly use that slave labour yourself every time you send it back, not to mention cause double the environmental impact from transporting everything both ways each time. Make no mistake, you're also an unethical douchebag. ;)
And I take the crown. I will continue to use said service as and when I please. They are after all one of the richest companies in the world. Hell I'm actually creating jobs here for people what do I have to feel guilty about ;).
