Any word when preorders open on OCUK?
https://forums.overclockers.co.uk/t...e-at-overclockers-uk-3090-3080-3070.18897451/
My preference is Zotac for the warranty but it will come down to whichever card I can get a waterblock that fits it quickly. That would now appear to mean it wont be the founders edition as nobody is making waterblocks for them as they are not "reference" this generation which is a shame,.
i would get the 3080 its a reasonable price but even that won't be able to give you a rock solid 60 in every game we will see though.Looking to upgrade from my 980ti, which card would suit me best for 4k 60fps?
My monitor is the BenQ PD3200U 32inch 4k monitor, with a max refresh rate of 60hz I believe.
I mostly play sims like Assetto Corsa/Competizione and now Flight Simulator 2020, so I'm looking at a rock solid 60fps and max settings, would the 3080 be overkill, or will the 3070 suffice?
I tend not to upgrade frequently, so ideally would like something to keep me going for at least 3-4 years, as the majority of my gaming is on consoles.
I have an i7 9700k and 16gb DDR4 ram as well.
FE is a reference board. The cooler is a new take on their FE design, as for cooling we've no clue yet as this is new for a nvidia reference card.
False the FE isn't a reference board I'm afraid adding to the confusion, but to the guys original answer there clocked higher than refrence but and oc card is, but the FE editions normally over clock better as they keep better binned chips for the FE models so I've heard
https://videocardz.com/newz/exclusive-gigabyte-aorus-z490-motherboards-are-pcie-4-0-ready
And I don't know how well that will be on Intel motherboards. But I will say that's going to be one expensive motherboard if you are on Intel with a CPU that's compatible.
Other then that AMD is your only upgrade path for PCIE 4.0.
Its more like there standard design like what AIB cards are using, but it doesn't state which 1s so will make it a nightmare for waterblocks as I want a water-cooled 3090 idealy FE but looks like ek aint got a block on realese for it![]()
So whats the nvidia reference card if the FE isn't it exactly?
Loads of people have swapped or are just about to swap to the LG 48" cx screens so we just need cards that can deliver the goods![]()
Looks like FE is out for me, i liked the look of them but i need 2xhdmi; one for tv and one for vr.
The Asus ones says they have 2 HDMI outputsDoes any card have that? I havent seen a single AIB card with more than one hdmi yet.
So the standard design is the one sold by NVIDIA, aka the founders edition.
No the standard design is what all the low end base aib models will use the FE is nvidias own custom design thats different to the refrence/standard PCB.... confusing I know
Bit overkill for 4k 60fps?
Still not sure if I get a 3070 for 1440p. Or go big with the 3080 which will allow my system to max out at 144hz?
Ive never gamed beyond 60hz not sure if I expect too much.
