- 14 Aug 2020
Hi all,
I'm a bit out of the loop with gaming setups at the minute, I built my last desktop maybe 6-7 years ago and sold it about 4 years ago. I've now got the space to get a gaming build back and whilst I've spent a good few hours here and there researching, I'm still quite lost with where to start.
Would really appreciate any advice, I'm really quite short on time to build one (the last one took me ages), so I'm not too fussed about paying a small excess to have it built out or buy a pre-built.
I'm hoping this budget can get me:
Basically all I have is a desk, chair, and an old MacBook Pro. So I need to start from scratch!
Edit: Not sure if possible but future possibility of hooking up a PS5 & capture card would be decent (assuming it works that way).
Thanks.
- AAA smooth FPS
- Dual Monitor (1 @ 1440p, 2nd is just supplementary)
- Capable of streaming good quality (1080p?)
- Gaming keyboard/mouse/speakers/headset (not sure how much to set aside for these)
- It'll be a high speed wired connection
- Case: I'd like to have this on show, I had a Haf-X case last time and it was waaay too bulky!
Thanks.
As you intend to stream, I'd stick with a Nvidia GPU as the NVENC (Nvidia's encoder) for streaming is fantastic - not many streamers use the x264 CPU encoder now if they can avoid it.
I'd maybe jump on this purchase sooner if you do decide to go for it, as not sure when the current £390 sale price ends.
