- 1 May 2013
- M28
Wonder of they have the Ampere mobile stack lined up yet?
Consoles are supposed to launch shortly before Thanksgiving so leaves early November as well.
Yeah first week in November. So hoping some press/leaks before then.
I think the blue tab is someone's interpretation and they are making the same mistake everyone did with Ampere, look at the block diagram, its 8X 20 = 160, look at the shaders, they are dual CU, just like Ampere.
I wish the card did come free with the game... A 3080 for £40 would be lovely
Yes, Watchdogs comes free with all 30 series cards (or so I've read)![]()
But by the same measurement didn't a slide for the Xbox show 26 dual CU to come up with the 52 figure?
No, saw that. Do you think it's genuine? 160 CU, 24GB but only 6MB L2? That would be well over 300W?I think the blue tab is someone's interpretation and they are making the same mistake everyone did with Ampere, look at the block diagram, its 8X 20 = 160, look at the shaders, they are dual CU, just like Ampere.
Awesome mate, thank you! Would you recommend founders edition or one of the after market ones?You’ll be fine, I’d go with a 3080 and save myself £750.![]()
Gave you a clue, not early NovemberI'm not American, when is Thanksgiving?![]()
Out of curiosity, does anyone know when the review embargo lifts on the 30 series?
I want to see the real performance figures so that I can evaluate my next GPU purchasing decision![]()
NVIDIA GeForce RTX 3080: 168% of RTX 2080 performance in CUDA and OpenCL benchmarks
https://videocardz.com/newz/nvidia-...080-performance-in-cuda-and-opencl-benchmarks
You skilfully avoided my questionI think it 'could' be a genuine GPU, whether we will see a gaming GPU of that size? i don't know.
Its not far fetched, in this configuration it has 10240 Shaders, the 2080TI has 4352 Shaders, the rumour was the 3080 had the same 4352 Shaders, and yet with its dual shaders it actually has 8704 Shaders. (which is X2)
In that sense its completely believable. What i struggle with is the XBox Series X is around 2080 Super performance with the same 26 Dual CU, or (3328 Shaders) so a 10240 Shader big Navi would be an absolute monster, 3X a 2080 Super, maybe more...
I remember a while back there was a company that you can send your phone to and they would immerse it in a certain stuff, making it waterproof. Don't know if they still do it or not but at the price of some expensive phones they should be like that already, and have tough screen protectors.
You are drawing unnecessary straws with that question. What would you expect the watts to be from a Uarch of that magnitude!You skilfully avoided my question. How many Watts?
All comes down to personal preference, I’ll be going FE as it’ll fit into my build better.Awesome mate, thank you! Would you recommend founders edition or one of the after market ones?
