Dual Screen Shortcut Keys
6 Jan 2013
Rollergirl
Hi,
Strange one here (to me, anyway) - I've plugged in a second monitor and have set to extend displays. I can't use the Win+Shift+arrow to switch windows between screens. I also can't use Win+arrow to snap left or right on the single screen. I'm having to drag windows across which is a PITA.
Any ideas?
Can you snap from the mouse still?
Yes, and having tested for a while I've noticed that pressing the Windows key only brings the menu up on the main display.
A workaround is to snap a window left on the secondary screen and then I get a choice to select another open window to snap right alongside it.
You've selected to extend displays so unless you've then set the main (primary) display in the settings, the start menu will only ever appear on the default display. Should still be able to snap with keys though.
That's rather odd! I use 3 at work and can use the shortcuts to move it around.
Is your HID service within windows services running?
Yes, Human Interface Device is running.
And now it's just randomly started working again!
ETA: Is there a way to drag the taskbar notification icons onto the second screen and have them stick there? I can drag them across but they end up disappearing after a reboot etc.
