** GORGEOUS NEW LG 4K MONITOR - LG 27GN950-B PRE-ORDER NOW **
OcUK Staff
23 Feb 2015
Overclockers UK HQ
Oh dear, my plan for an Xmas upgrade present for myself may have just gone from OK to 4K...
• 27” UHD 4K (3840x2160) Display
• Nano IPS 1ms (GtG)
• 144Hz / NVIDIA® G-SYNC® Compatible
• VESA DisplayHDR 600
• VESA DSC (Display Stream Compression)
Pre-orders open now, medium-ish volume of stock landing in October. Pre-order to bag one!
LG 27" 27GN950-B 3840x2160 4K NANO IPS 144Hz 1ms HDR 600 FreeSync/G-Sync Compatible LED Widescreen G @ £749.99 inc VAT
Display Resolution 3840x2160 UHD 4K, Display Size 27", Refresh Rate 144HZ, FreeSync, G-Sync Compatible, 1ms Response Time, Contrast Ratio 700:1, Panel Type NANO IPS, Height Adjust, Tilt Swivel , DSC
Only £749.99 inc VAT.
ORDER NOW
Still its a good step in the right direction, wonder if it supports hdmi 2.1 ports
It would have to to support 4k@144hz, no?
HDMI YES(2ea)
HDMI (Max. Resolution at Hz) 3840 x 2160 @ 60Hz
DisplayPort YES (1ea)
DP Version 1.4
DP (Max. Resolution at Hz) 3840 x 2160 10bit @ 95Hz
Featuring VESA Display Stream Compression (DSC) Technology, 27GN950 supports 4K hi-resolution, 144Hz hi-speed refresh rate with 1ms (GtG) response time, HDR and G-SYNC® Compatible as well as covering 10bit colour by a single DisplayPort connection, and reducing visual loss.
They need to get 4K 144Hz @ 32" released ASAP! 27" is just too damn small for 4K. Have tried to get on with it, but after the experience of 32", I just can't do it. Looks like there are a couple of models due early next year, but it's taken far too long. At least the Viewsonic XG320U will have HDMI 2.1 for those that want it, and not be a million miles off the price of this LG, so personally, I'd wait. The extra size alone is worth it.
I mean for general desktop uses not gaming. If the text on a 27” screen at 3840*2160 is too small how do 27” iMac users cope. Scaling??
As above, OSX scales far better than Windows. Some apps look downright awful at anything other than 100%, and 27" is just too small for that @ 4K. Could be argued that 32" is also in some cases, but it's far more usable.
