I have an issue where I have two HomePod (stereo) and an AppleTV 4K, when watching/listening I get a momentary pause in the audio (max of probably 1 second). The HomePods/Apple TV are all on the same AP, connected to their own 5Ghz SSD.
I've disabled everything I can think of, no Wifi AI, nothing fancy!
Controller = 5.14.22
AP-AC-Pro = 4.3.20.11298
UniFi Switch 16 POE-150W 4.3.20.11298
I bet if I enabled wifi on my Virgin Media Router and connected them to that there would be no issue, debugging why this stuff doesn't work is almost like a "full time job"
In fact I just tried that for "giggles" and guess what, no drops in sound!! (I've raised a support ticket for what good it will do!)
I'm starting to lose the faith, in the last few weeks I've had:
Borked IW HD AP (support were basically no help)
Problems with HomePods (that can be fixed by basically not using the Unifi products)
Client historical data has been removed without warning from 6.0.13
Some rudeness from a Ubiquity member of forum staff about the above (basically failing to even acknowledge it's happened!)
Cheers
HEADRAT
Cheers
HEADRAT
