You need to rerun SOTTR using the settings I posted earlier in the thread.
If you don't use RTX then yes you will get a higher fps but that defeats the point of buying a 3000 series card.
I am Sorry but I don't see the point SMAA4x at 4k is pointless why would anyone use that at 4k the higher the resolution the less AA is needed, fine at 1080p smaa4x would be good but at 4k your cutting your fps in half.
Also Smaa4x & TAA effects texture clarity the most something I bet is very important to most people.
Standard SMAA is better way to go less of a performance hit, good aa, Less effects on textures.
4k Max RTX on - 58 ( Ray-Traced Shadows Ultra )
4k Max RTX Off SMAA DX12 - 39 ( Ray-Traced Shadows Ultra )
4k Max RTX Off SMAA DX11 - 55 ( Cannot do )
4k Max RTX Off TAA DX12 - 38 ( Ray-Traced Shadows Ultra )
4k Max RTX Off SMAA4x DX12 - 27 ( Ray-Traced Shadows Ultra )
Now be clear i'm not getting a 3000 card, not till later when games need it or any AMD if it is any good which I don't think will be.
I ran a load of tests if anyone needs any other games ones let me know Link Here
