Does this 7850 card support 60Hz at 3440x1440?
10 Feb 2003
Haywards Heath, West Sussex
I recently bought a 35" widescreen monitor to run off my iMac as it's backlight had failed. It works fine at 3440x1440 @60Hz vi display port. However I also have it hooked up to my PC via HDMI.
Running the monitor from the PC via HDMi I can only get 30Hz at 3440x1440. If I want 60Hz I have to drop to 1920x1080.
I am using a HDMI 1.4 cable so I know that supports high res and refresh rate so I am thinking the limitation must be the graphics card? It is old I know but I did't think it would be this limited? I cannot find out the refresh rates it supports at different resolutions so thought someone here may know?
If it does, it's likely it can only do it via DisplayPort.
That said, I've been able to up the framerate using better DP cables before. So try and get a good one too.
Yeah, you'd have to use DisplayPort. I'm currently using a 7970 and it does 1440p/144Hz just fine over (mini) DisplayPort, but only 1440p/60Hz over HDMI, so wouldn't be enough bandwidth for ultrawide.
IIRC GCN2 Cards (7790/260X/290X etc) were the first cards that supported the required displayport and hdmi versions - older cards than this would only drive 4K monitors at 30hz.
Edited to clarifiy
These first-gen cards have DisplayPort 1.2, so can actually do 4K/60 over that. You could just buy a cheap DP to HDMI adapter to hook it up to a HDMI port too.
Apologies yep - it was only HDMI that wouldn't do 4K/60 on the older cards.
FWIW and possibly unrelated but I had horrendous problems getting my 7870 to display 4k @ 60Hz on my monitor using DP. I would have to turn the monitor off and on multiple times before I got a picture, tried different cables and the problem persisted, got a cheap RX580 and the problem went away so possible the older GPU's may have some unexpected issues as well.
