Corsair h110i GT fans 'surging' while playing games
10 Nov 2015
Hi,
My H110i has been faultless for the past almost five years until just recently when the fans have started ramping up, then slowing regulatory while paying games.
It normally is set with a custom curve on Corsair Link so that there is a gentle progression of increasing fan speed and all is usually well.
Thinking that it might be a software issue I have installed iCue and set a custom curve with the H110i temp as the sensor.
No luck, as soon as I start playing COD, for example, the fans start surging.
It is really annoying and, as the past five years have shown, completely unnecessary.
Any ideas? It doesn't do it when I am not playing games. Is the H110 on the way out?
So hold on your cooler fans go faster when the CPU is under load ? mine do that too,then when the CPU is no longer under that load the fans slow down again this happens on and off throughout the day for me :).
It's not that they get faster under load, which is normal, it is that they suddenly increase their speed to max and then decrease their speed in around 2-3 seconds. It seems that they are 'pulsing' when under load, which they have never done before.
Ah I see what you mean yes, I have mine ( not under load) set to balanced and when under load I set them to extreme when im in game then just set them back to balanced once im done with a game.
In passing iCEU is a piece of ****! I mean the concept is fairly sound but Corsair never manage to release it without a load of serious bugs.
Monitor the water temperature. See if it doing anything weird. The water temperature sensor is in the head so if there is any problem with circulation then you can see that with peculiar behavior in the water temp ( like the water temperature slowly rising over time or sudden fluctuations in temperature that all seem to ignore any increase in fan speed).
