MSI Ventus there are no holes on the back. The question is whether it is bad or good.
I noticed that. MSI are kind of the odd one out for the big brands.
Will be interesting to see if it has better, or worse cooling than the rest.
Sapphire have had that blow through design since the Fury, and even with Vega Use it.
Powercolour also did similar with the Fury, and Vega with gaps in the heatsink to blow through.
As for the 3080s.
Many have cut outs, and the likes of Gigabyte actively advertise that blow through
Galax
KFA2/Galax clip on fan for that rear cutout to have even more air flow.
Inno3d
Asus
Zotac
Gamers Nexus still reported it. I don’t think they would have repeated the claim if they had found any evidence of some other issue.No thats what Nvidia claims. Might be true. Might not be,.
Nope they wontWonder if the seals will start to break tomorrow
TBH i can only see it as problem with my Memory overclock cause.
I got Fan standing on my Titans backplate blowing air directly on to DDR modules. Will need to check Stability after upgrade of memory 2 hours of memory testing hehe. Possible ill need to bump volts a bit ram. Will investigate.
@Adrian1976 this is what I consioder proper Overclockers cooling while at it poped ya photo of my passive radiator with 2l bottle next to it so ya see what sort of cooling power im talking about. Had to move stuff that stands in front of it to grab photo.
@humbug what ya think ?? hahahaha
Just stick a bit of cardboard in between them, use sellotape to hold it in place if it's blowing aboutProbably because the hot air will be focused into a smaller area right into the CPU cooler and over the ram.
MSI Ventus are the budget coolers without zero-fan-idle mode.MSI Ventus there are no holes on the back. The question is whether it is bad or good.
Just stick a bit of cardboard in between them, use sellotape to hold it in place if it's blowing about![]()
guru3d already "accidentally" put up a 3080 benchmark
that's what happens when you move the NDA, people forget or don't get the news and think the first NDA still applies
I don't have that game and I'm not paying £7.19 to run the same benchmark with my 2080ti. Anyone have it and a 2080ti?
Think a 2080Ti hits around 40-45ish with dlss + rtx. Not really the best optimised title going so hard to judge.
Is that at 1440p?Think a 2080Ti hits around 40-45ish with dlss + rtx. Not really the best optimised title going so hard to judge.
So that points to a 30-40% uplift in that title's benchmark?
Reviews are going to be VERY interesting. If AMD have brought it this year at the high end, NVIDIA are in trouble which would explain why NVIDIA's pricing stategy is so forgiving this yeae.
And if it's at 4K then it's not looking good.It his 2080ti 45fps number is at 1440p using the same settings then the 3080 is 50% faster in this RT+DLSS benchmark
