let's see what others go in at won't know until tomorrow 2pm though. but i see your pointIndeed, 2nd most expensive retailer for pc components.
Probably because you have them disabled in your user settings.
Had a feeling hopper would be a big upgrade, but if that is true it might be much bigger than I expected.Let's make a new hype thread on RTX Hopper, now that Ampere's performance stats will start trickling:
https://www.tweaktown.com/news/6918...r-gpu-arrives-ampere-smash-intel-amd/amp.html
Hmm I'll take a look, seems limited from a mobile, not at the PC at the min so not sure, thanks.
Nope, don’t think so. Pretty sure from what I read it was 65c IDLE.From what I am reading the founders edition runs at 65c on FULL LOAD , if thats the case its pointless buying custom cards at such a high prices , I must admit I normally buy MSI Brand but I am not paying £829 for Graphics card that I can buy from NVIDIA direct for £650.00 that will run at the same speeds in my system as custom card.
I'd like to think if this was the case then AMD might have had the nous to leak some numbers but they haven't, which leads me to believe they can't get near the 3080![]()
Reviews out later today? I expect it's going to be a story of: Brilliant performance, but user experience tempered by high power and heat. Prices look reasonable, but only against the unreasonably high 2000 series. Nvidia power efficiency improvements aren't enough, anyone can get high performance for high power, progress needs to come from more efficient architecture and silicon, not better coolers!
AMD have a great chance here, not to match the 3090 (which is irrelevantly expensive for almost everyone), but to be competitive with the 3080 at something like 220-250W and slightly cheaper.
I can't see there being a rush for the cards once the reviews have been seen![]()
350watt is a lot of power draw to a card to cool. If 250watts is 80c at load on an aftermarket cooler then 350watt on a founders card is (my guess) a lot more than 65c at full load.
Also the reason the 380watt 3090 is so huge (huge hsf) and not tabelled a ‘Titan’
‘Titan’ cards are aimed at the professional market which run cool / quiet for long periods of time. A 380watt draw card will churn out a LOT of heat and will either be noisy or red hot (or both)
The heatsink reaches 65 degrees Celsius from what appears to be 34.4C idle temperature. This is the temperature of the heatsink, where the cursor is pointing, not the highest temperature of the card. The PCB is clearly hotter, but the values have not been provided.
Please elaborate. Not sure what you meanNo man, TDPs..
Flying out the doors mate! Can't keep up with stock levels etc etc, better hand that £850 over now as it may bemonths,weeksor just days before you can get your hands on another!
I assume you're referring to this:
https://videocardz.com/newz/nvidia-geforce-rtx-3080-founders-edition-flir-thermal-footage-leaks
But I'm sure we will see better testing results come 2pm!
