Think I had a bit of a brain fart tbh, thought I read on their website the heat sink is aluminium but it's nickel plated copper, never mind.....Yes.
Nickel and copper are fine together
Josh.
https://www.ttpremium.com/product/pacific-rl360-plus-rgb-radiator/German-Made Anti-Corrosion Materials
Without compromise, the radiator is designed with high-quality German aerospace-grade materials and constructed with zinc, the most common anti-corrosion agent. Although this protection will gradually degrade as the zinc corrodes away over time, it provides the best means to reduce electronic conductivity and can withstand scratches to the zinc layer. Corrosion potentials of zinc alloy aluminum can be reduced by 55.6% after brazing.
Great, using sacrificial corrosion to protect the radiator - not sure what that'll do to the rest of the loop!
Post above yours.Sorry, I don't quite understand what you mean by that?
Post above yours.
Just a quick question i have got a nickel mobo+cpu block + a nickel GPU block am i right in thinking then i MUST go for a nickel rad? however unless im begin silly i cant seem to find a nickel rad they all seem to be mainly aluminum?
It will be nikel plated copper most probably, you can safely use a 'standard' radiator ( copper/brass).
Some might mention aluminium housing - that would also be OK as the housing doesn't make any contact with the liquid, but don't use a 100% aluminium radiator
https://www.overclockers.co.uk/ek-w...c-360-slim-triple-fan-radiator-wc-9s0-ek.html
Will work ok as its copper tubing?
