Just bought this new 3080 PC - Did I rush or should it be pretty decent?
3 Sep 2020
So really wanted a new gaming 3080 pc yesterday and finally found one online which was not on a slow or crashing website
However now that I have bought it, I'm worrying if i made a good choice or not as Im pretty new to when it comes to whats good in a system and whats not.
Just a bit worried i could have got better if I had waited and not rushed just to get one
It was a couple hundred less than the system i originally had my eye
These are the specs:
Description :
3rd Gen AMD Ryzen 9 3900X 3.8Ghz Twelve-Core Processor
Manufacturer :
AMD
No. of Cores :
12
MEMORY
Description :
16GB (2x8GB) Corsair Vengeance RGB Pro DDR4 3200MHz Dual Channel Kit
Speed :
3200
GB :
16GB
HARDDRIVE
Description :
Samsung 970 EVO Plus 500GB NVME M.2 SSD (up to 3500MB/s R | 2300MB/s W)
Description :
Seagate BarraCuda 2TB Desktop Hard Drive
Interface :
M.2
GRAPHICS
Description :
NVIDIA GeForce RTX 3080 10GB Graphics Card
POWER SUPPLY
Description :
CORSAIR RM Series RM750 80 PLUS Gold Fully Modular ATX Power Supply
Wattage / Rating :
750W, 80 Plus Gold, Fully Modular
MOTHERBOARD
Description :
Gigabyte X570 Aorus Pro AMD AM4 X570 Chipset ATX Motherboard
COOLING
Description :
Corsair iCUE H100i RGB PRO XT Liquid CPU Cooler
WIRELESS CARD
Description :
TP-LINK Archer T6E AC1300 Dual Band Wireless PCI Express Adapter
LIGHTING
Description :
3x Corsair LL120 RGB 120mm Dual Light Loop RGB LED PWM Fan
Other than that there wasn't more info like soundcard or ports etc.
As long as this sounds like it should run new games at 1440p on ultra with great framerate, should be ok but just wanted to ask those with more experience in gaming builds.
Ideally i wanted 32gb ram and another ssd but i imagine these things are easy to add and install afterwards
Will be fine !
Personally would swap out HDD for larger SSD as you can always had in HDD for pennies later !
Board fine, CPU fine. Could even drop to 3700x to save cash !
Did the site not sell x570 Aorus ultra as that has WiFi built in and prob save a bit instead of having add in WiFi card etc
Nothing wrong with the actual parts list. You could have gone with some cheaper alternatives if self building, but if you needed it quick then it is fine :)
