Hi
I have a Corsair 220t case like the one linked below
https://www.overclockers.co.uk/cors...k-tempered-glass-cc-9011190-ww-ca-255-cs.html
It comes with 3 intake fans at the front as standard, to which I added 1 exhaust at the back. Currently having 3 intake 1 exhaust.
I have recently purchased a new G card, it is too large for the case, therefore since changing case would be a haste, I have been told that I should remove the middle front fan, to allow it to fit.
Due to having only 2 fans for intake at this stage, I was advised to install a AIO cooler for my CPU.
As for the AIO radiator fans (2 of them) - I will install at the top of my case, should these be exhausts or intakes? as I believe intake is recommended by manufacturer.
If the latter (intakes), I will have 2 front fans for intake, and 2 at the top (radiator fans for AIO), and just the one exhaust at the back - would this work? - It is a small, mid case.
Or, if the radiator fans would be fitted as exhausts this would mean I would have just the two front intakes, and 3 exhausts, 2 at the top one at the back.
Which route do I take?
I hope this makes sense.
If anyone has any alternative ideas, please feel free to advise accordingly.
