- 1 Oct 2010
Good evening,
So back in February 2019 I bought the Eisbaer LT360 from OCUK, received it and noticed it was not working, so sent it back and got a new one. On getting the new one I managed to get 5Ghz out of the 9900K straight out of the box, simply changing the multiplier up to 50.
After a few months the PC would suddenly start rebooting and crashing randomly, which after looking into it I decided was likely the CPU being clocked too high and causing issues. I decided to go back down to 4.8Ghz and everything was OK again.
The thing is the CPU runs pretty hot (I know it does generally), hitting 92C if I run the short CPU Mark test via PerformanceTest by PassMark Software (I use the trial version, takes a couple of minutes or so to just do the CPU test, so by no means a 'taxing' test in terms of duration). This is slightly higher than I remember it getting when I was running it at 5Ghz when I first built the PC, which is somewhat worrying.
In recent weeks I have noticed an audible humming sounds that I cannot remember hearing before when I first built the PC, so I am also wondering about whether there is an issue with the cooler. Needless to say my initial experience with having to return the cooler has not helped my confidence in the product, and I am wondering whether it is worth upgrading to a H150i?
Aside from the cooler, could it be the CPU at all? I highly doubt it as my PC is very stable at 4.8Ghz, my only concern is that the CPU is getting pretty hot during that test I mention above and a worry that the cooler is on its way out already - am I wrong and the heat might be CPU related? I do not plan on upgrading my PC for many years, 3 at least as I see little reason (unless something drastic happens) to do so - this CPU should not show its age for quite some time.
In case it is useful my case is the Lian-Li PC-O11 Air Midi Tower, any other cooler recommendations would be welcome
Any advice would be greatly appreciated
