A 16GB 3070 will not match a 10GB 3080 in performance, the 3080 is still quicker due to the higher specs. However, a 16GB 3070 may age quite well if it has 2080 Ti performance with better RT, and DLSS will allow it to play some games at 4k 60fps without running out of VRAM.10gb will likely be enough but will be a bit of a sour taste for most who had just shelled out for a 10gb 3080 only for it to be matched by a 3070Ti that then has 60% more memory a few months later.
20gb 3080 is one thing but offering a 16gb 3070 would just totally **** in the face of anyone who bought a 3080 at launch
Nvflix? Ampere Prime?Have cancelled my netflix subscription since the entertainment thanks to this launch has me all set for the next few months!
I think that the 20GB and 16GB VRAM versions are essentially similar in principle to Super versions even if they don't have higher clocks... they are improved versions of the original cards and purposefully being saved until only a short time after launch, one month or so. That is not nice to launch day owners who didn't have that option available and would likely otherwise have bought the best card they could.A 3070Ti may come very close though if they end up releasing one.
I don’t think there is much room for supers this time around there is very little spec and performance wise between the 3080 and the 3090 not really anywhere for a Ti to sit per say unless they half the memory. And even then that would render the 3090 useless as it is being marketed as a more gaming oriented card.
Possibly may see a refresh though as we know Samsung 8nm is rather garbage.
A refresh to the far superior TMSC 7nm next year would imo be even more of a gut punch than a Super refresh of the inferior Samsung 8nm process.
Why?20gb 3080 is one thing but offering a 16gb 3070 would just totally **** in the face of anyone who bought a 3080 at launch
I think Nvidia have put their partners and retail sellers in a difficult position for the time being.
He comes over so clueless with some of his posts at timesI would imagine the 3080 will still perform better with the higher CUDA core count?
What I don't understand about the leaks around the 16GB 3070 is this will kill sales of the 10GB 3080.
It will just be far better value to buy a 16GB 3070 than a 10GB 3080.
I'm thinking I should honestly cancel my order and wait it out. It's always better to buy when all players have played their hand.
And it's not like OcUK can fulfil my order anyway.
Also although the money isn't a problem for me splurging almost £700 on a GPU does make me feel a little bad. I love my gaming but £700 for a GPU!
I'm also only at 1440p so maybe a 3080 is just overkill.
Even the thought of a £450 Playstation 5 sounds nice.
If a 2080Ti has the grunt for 4k with worse RT performance than Ampere, then the 3070 will have the grunt to run at 4k with better RT performance and of course DLSS.Will it? the 3070 is going to be slower than a 3080 and the 16gb on the 3070 will only come good at higher res but then the card doesnt have the grunt for 4k.
Some clueless people willWill it? the 3070 is going to be slower than a 3080 and the 16gb on the 3070 will only come good at higher res but then the card doesnt have the grunt for 4k.
plus with some AIB 8gb 3070 cards already more expensive than some 3080 cards, i can see the 3070 16gb costing more than the 3080 across the range. Are [people really going to buy the 20% slower 3070 for more money just cause its got 16gb?
Wow this launch is a total *********** from NV
The cards are overvolted and pushed to the max with no OC potential, rushed out with no stock availability just to get them out before AMD.
This just shows me NV is afraid of big Navi.
They could have brought sub 300W cards with only 5-10% less performance but for some reason they squeezed the last bit of performance from them with +50W power consumption.
NV basically made an old AMD card:
Lots on computing power but not utilized fully
Overvolted GPUs pushed to the max
No OC potential
Buggy drivers
The 3080 can overclock ok.
3070 16gb needs to be £499 to be a good price, maximum £549. But then that is getting to close to £649 which is what I paid for my ASUS TUF. I would rather take the extra performance as by the time I need 16gb I will be on a next gen card.
