@Jan_C apologies in derail this thread re the eagle power connectors i created a thread just for that to be discussed..
now re your situation have you tried to under volt the card sounds like its a hard power limit fault or something happening ...worth a shot at least
If you run GPU-Z what bus speed does it report the card is running at?
It needs two separate cables. The connectors are the bottleneck.sorry to butt in. but about the multiple 8pin connectors. are you saying it needs to be 2x cables each with a single connection from the psu striaght to the gpu? or is it ok if one cable is split into 2 connections to the gpu? also does it matter if its a 6pin with 2 pin or does it have to be a single 8 pin? Because the evga psu I have has split connectors that are only 6pin with a 2 pin split to make 8pin.
No, use the cables you have but don't daisy chain the connectors. IE for each 8 pin use a separate cable, don't use one cable which has 2x 6+2 connectors on it.were would i buy these connecters ..beacuse from what you are saying it sounds like the ones that are with my evga psu are not going to be compatibale with any 30 series card.
i only have 2x cables both are split into 2 connections. so its a max of 4 connections.No, use the cables you have but don't daisy chain the connectors. IE for each 8 pin use a separate cable, don't use one cable which has 2x 6+2 connectors on it.
So use the two cables. Some people try to connect both 8 pins with the connectors from a single cable, which can melt the connectors or the cable.i only have 2x cables both are split into 2 connections. so its a max of 4 connections.
but you said it should be a sepepeart connection..there not sepereate i have 2 cables each with 2 6+2pin connectors.So use the two cables. Some people try to connect both 8 pins with the connectors from a single cable, which can melt the connectors or the cable.
As long as you only use one of the connectors per cable you are fine then. The cables are separate, and can each carry ~150w.but you said it should be a sepepeart connection..there not sepereate i have 2 cables each with 2 6+2pin connectors.
You need two cables: one end of this cable plugs in your PSU, the other end has either a 6 + 2 pin connector or an 8 pin connector (Molex PCI-e connectors). These cables are also often labeled with PCI-e printed on them.
If you have two cables that have *two* 6+2 pin connectors on them, then use one of these 6+2 pin connectors from one each of these cables.
So use the 2 cables but just plug in one of the 6+2 ends from each cable.I have 2 cables that are like this.![]()
yea but i need to plug in 3 ..not 2.. thats why im asking.So use the 2 cables but just plug in one of the 6+2 ends from each cable.
It has been said about 4 times already...
