Upgrade advice
3 Aug 2014
Want to update my pc,
what would be a good upgrade for this graphics card and Processor?
Processor
Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
Video Card
AMD Radeon R9 200 Series
running on this board:
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: Z97P-D3
any help would be appreciated. Pc runs fine so dont see a need to totally replace it, but would like to prepare to run a few newer games.
Full system spec please.
Hey, sorry for the delayed reply
this what you need.
Time of this report: 9/25/2020, 02:26:06
Machine name: BUMBLEBEE
Machine Id: {DDCFE592-C9E5-4EEA-A7E4-150468361571}
Operating System: Windows 10 Pro 64-bit (10.0, Build 18363) (18362.19h1_release.190318-1202)
Language: English (Regional Setting: English)
BIOS: F8 (type: UEFI)
Processor: Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz (4 CPUs), ~3.5GHz
Memory: 16384MB RAM
Available OS Memory: 16246MB RAM
Page File: 7408MB used, 11268MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: Unknown
DxDiag Version: 10.00.18362.0387 64bit Unicode
Operating System
CPU
Intel Core i5 4690K @ 3.50GHz 48 °C
Haswell 22nm Technology
RAM
16.0GB Dual-Channel DDR3 @ 931MHz (10-11-10-30)
Motherboard
Gigabyte Technology Co. Ltd. Z97P-D3 (SOCKET 0) 30 °C
Graphics
ASUS VN247 (1920x1080@59Hz)
Intel HD Graphics 4600 (Gigabyte)
4096MB ATI AMD Radeon R9 200 Series (ASUStek Computer Inc) 43 °C
CrossFire Disabled
Storage
111GB KINGSTON SV300S37A120G (SATA-2 (SSD)) 30 °C
1863GB Seagate ST2000DX002-2DV164 (SATA ) 27 °C
1863GB Seagate ST2000DM001-1ER164 (SATA ) 27 °C
Optical Drives
ASUS DRW-24F1ST a
Audio
Realtek High Definition Audio
think its Radeon R9 290
You have a few options for upgrade
You could upgrade cpu and motherboard but you would have to get some memmory as well.
Zen 3 is due for release in October so I would wait till then.
New gpu need a buget for this if you decide.
A larger ssd to put games on , do you have your games installed on your ssd alredy ?
What games do you want to play ?
I ideally staying within a £500 budget would be ideal otherwise i just get into the territory of might as well spec a whole new pc.
game wise cyberpunk is the game that i would ideally like to be specced for, not even top spec just solid.
I think i will buy a new ssd, currently sit most of my games on a 2tb firecuda hdd and just keep the small ssd for windows related stuff.
I'd probably go for a nice high refresh rate IPS monitor and something like an RTX 2060/super/2070.
Also overclock your current CPU a bit.
What power supply do you have? Make, model, wattage
If you grab one of the GPUs mentioned, definitely recommend buying used the market is getting more of these in with 30 series launched (haha kinda) now.
You can get 2070 Supers for £270-300 region used. Which are great cards up to 1440p still, so @ 1080p they’ll run great.
Yeah great PSU so no problem there.
Prob would recommend something like a 2070S used for £270-300 if you look about :)
Depends how much you're looking / happy to spend?
Will be keeping an eye out for one. Have had a brief look and they are out there. don't want to go too lavish at the moment with covid and all. Got to keep a few pennies back in case it all goes crap :D
appreciate the help
