Very interesting, mate. Thanks for that. Although we have to admit that it does strongly depend on the game. From their conclusion:
"We also did a test run with the power limit at the 480 W maximum ASUS provides. 480 W is much higher than anything available on any other RTX 3090, so I wondered how much more performance can we get. At 4K resolution, it's another 2%, which isn't that much, but it depends on the game, too. Only games that hit the power limit very early due to their rendering design can benefit from the added power headroom."
Still, if I was going to splurge on a 3090, it does seem worth saving up for the Strix.
The 480w power limit slider on the strix is nuts and definitely for after market cooling applications. After looking at reviews I personally wouldn't move the power slider any further, I may try auto OC and memory OC to see if I can get more with stock power but that it. Id put it under water if I'm going to raise the power limit.
Going by how much gpu boost 5.0 moves with temp changes and what clocks they got with the card set to 480w on stock cooling, it looks like a good loop this card should be able to do a locked 2100 to 2200mhz
