- 3 May 2013
- Ireland
Hey guys. I'm planning a whole new build with an custom loop water cooling setup, and I want to mount my GPU vertically. This runs into the problem of not being able to fit my sound card in.
I was originally planning to just upgrade my existing PC but a whole fresh build is the better choice by far. The only part I'll be recycling into the new build is the sound card - Soundblaster Zxr.
This particular sound card plugs into a PCIe slot on the motherboard, while it's daughtercard just mounts into a blanking plate slot on the case.
Is it possible to vertically mount the GPU in such a way as to leave access to the bottom PCIe slot on an motherboard (ATX)?
Or alternatively, could I perhaps vertically mount the GPU closer to the glass side panel of the case and then also vertically mount the sound card (and daughtercard) behind it using a second PCIe extension cable? Worried this option may leave me short of room for wc tubing into the GPU block.
Case is a Lian Li O11 Dynamic XL, so there's plenty of room but just not sure. And I know the GPU size is a factor here too. Note that I've already got the case but haven't bought a GPU or anything yet.
Anyone else mounted a GPU vertically and been able to fit their audio card in too?
