And when it does, Ill buy the 4090
Same!
wow ... what a thread.. anyways all crying 3090 purchasers are fools .. mind your own business it's their money and for all you know they require more than 10GB VRAM ... or just want the fastest card and don't update every new shiney comes out so keeping it for a good few years.
It's pretty rude to justify what you think is right at the people buying them, they may have their reasons. Yes for gaming for now the 3080 with 10GB will do, but reality is as we all know for future 4k+ resolutions and new games with high textures the 10GB will not be enough but if you are a 1440p and 1440p Ultrawide user the 10GB will be fine for many years, by that time the card will not be fast enough before VRAM becomes an issue.
Guys we are all mad about what Nvidia has done to some point and reality is in most cases if the 3080 20GB was available I bet you most people using a 3090 for gaming only would have got that.. Now lets be honest Nvidia are going to charge a premium for the 20GB model and clearly not coming out just yet , they need to milk the 3090 sales first. But lets hope it appears soon, I keep looking at the 3080 and 3090 and honestly getting fed up of both cards they both have their issues, Nvidia did that deliberately .. So people that are fed up to some point thought sod it 3090 and wont upgrade for a few years and pay the Nvidia tax this time round.
But also lets wait and see what AMD brings out soon to the GPU area and then we can all decide what was really best value... depending on our needs NOT wants but real use needs.
Lol. Thats not how it works at all.
Most PC games are Ports which are upscaled. Not PC games downscaled to consoles. Have a look at Warzone MW. It looks like **** on PC.... No matter how much you turn it up.
Also Nvidia just abandoned SLI officially.
I think I will go with the graphics on a high end PC thanks.
And Consoles really suck at a lot of the games I play, those key pads just don't have enough buttons.
Isnt that my point?
Err what?
did you understand my point at all?
Show me proof that 10GB isnt enough for games at 4k.
Someone said Horizon Zero Dawn. That uses 7.2GB and has a Vram memory leak.
In the next 2 years is there a game that will USE 10gb?
I understand your point and you are wrong.
If I blow 3k on a couple of GPUs that are worthless in a couple of years time I don't care, all I care about is what they can do now.
What can they do now which is special?
You really are offended aren't you?
You are wrong! Most games that are cross platform end up releasing with higher resolution graphics than the console including the texture quality! I'm not even going to bother giving you links to sites that shows this frequently using comparisons. But GTAV is one good solid example: It released later for PC simply because of all the extra work that got put into it. Crysis and Crysis remasterd is another very easy example where texture resolution is much higher on PC! Just go look on Youtube if nowhere else and stop lying to yourself to back up arguments that exist only in your own head.
Oh, and the last nail in your coffin for "consoles leading the way" -- Why has the PC had ray tracing for a while now and not consoles?
In 2 years time the mid range 4000 series will make the 3090 look 50% of its speed and 25% of its value. Next gen consoles will push up graphics standards and require much faster GPU's over the next few years.
Dont justify this purchase with "it will last me 4 years" kind of mentality.
Unless you are taking Radox's mentality it will only lead to buyers remorse.
you clearly dont understand how things work.
Do you realise that games are not VRAM limited? Do you know what VRAM allocation means? Do you know that frame rates are 99% always Core limited? Never in the history of PC gaming has the high end card ever not had enough VRAM.
You say that but a normal 3080 isnt that much faster than a good overclocking 2080ti from 2 years ago. In fact the difference is so small that I was thinking of keeping the 2080ti for another 2 years.
so no, i doubt a mid range 4000 will make the 3090 look 50% of its speed. Looking how Nvidia are doing things and they cant just turn up the wattage to 11 like they did this time (all the none dlss and rt gains from the 3080 came just from the power boost), I suspect we will be looking at a 4080 which will be 10-20% faster than a 3090. So yeah people can finally afford to have 3090 performance.
Will that make a 3090 owner upgrade? I doubt it. In the meantime they have had two years playing 4k games between 60 and 120fps.
