Stock Jet plate in EK Velocity
11 Jul 2003
Telford//west mids
Hi hope you can help other wise I'll need to strip the block down as I've got the full nickel velocity cpu water block on my 10700k and temp's are good but the pdf says it should have the J2 jet fitted,I asked EK but they couldn't say.
Jet plate just directs the water flow better so if your temps are good then I wouldn't bother.
https://www.yumpu.com/en/document/read/51231725/step-1-general-information-on-product-ekwb
