Is a 3700x enough to cope with a 3080?The 3800
Sorry yes it's Ryzen 7. Thanks3700x is a ryzen 7 and should be more than enough for a 3080
How much is the bottleneck? I have a 3700xI may be appologizing as well, after posting I did a bit of research and I found some people saying the 3700x does bottleneck a 3080 a bit so maybe better to google it and see what you can find
I don’t fully understand the term bottleneck tbfI have a 3700x and I’m getting a 3080. Of course the 3700x will bottleneck it sometimes. You always have a bottleneck no matter what. A 10900k will even bottleneck it in certain titles.
A 10700k or so will get you a little more FPS, especially at 1080p, but for 1440p it’s less, and 4k won’t make a difference.
If you are CPU bound by the 3700x, the FPS will tend to be so high it won’t make a difference.
found thisHow much is the bottleneck? I have a 3700x
Jeez that’s bad
Tbf I’m aiming for 1440P 144hz I think I’ll be fineI have added a second link where it is said a 3700x is a recomended cpu for 3080
Jeez that’s bad
If you're gaming at 1080p on a 3700x and 3080 you really need to get your priorities straight. Totally useless statistics. For 1080p get a 3060 when they exist don't waste money on a 3080 for 1080p.Jeez that’s bad
1080p. Most benchmarks I’ve seen a 10900k is 7-10 percent faster on 1440p
im aiming for 1440p 144hz not 1080If you're gaming at 1080p on a 3700x and 3080 you really need to get your priorities straight. Totally useless statistics. For 1080p get a 3060 when they exist don't waste money on a 3080 for 1080p.
Good, that's ideal then but I was talking to OPim aiming for 1440p 144hz not 1080
