- 17 Jun 2012
I've been out of the loop for a while, I have an ITX case that will take a full sized GPU and I fancy putting together a cheap gaming rig for 1080p, not fussed about mega FPS just a solid 60 is fine.
What would be the best used VFM GPU for this? last card I had was a 1070.
Like wise what would be the best VFM board and CPU?
Budget isn't set in stone as it depends on what I can get- I.E. if another £50 makes a big difference then I will spend it etc.
I also could do with a decent 140mm AIO if they're still a thing?
