Permabanned
- 5 Apr 2006
As title...just bored and thinking why isn't there any cheap plastic fittings for pc watercooling?
Probably due to aesthetics.As title...just bored and thinking why isn't there any cheap plastic fittings for pc watercooling?
Would you honestly trust cheap plastic fittings
It is.it can't be just down to looks.
It inspired the thought, in that certain types of plastic fittings might also break down and leech particulates, yes...You're thinking about the plastic used to make soft tubing I assume?
I think acetal is too brittle to use as a compression fitting, isn't it? You'd want something with a bit more flex.What about the plastic used to make waterblocks?
Would you honestly trust cheap plastic fittings around potentially thousands of pounds worth of computer equipment? I know I wouldn't!
It's probably been tried in product development, but I suspect plastic doesn't have the longevity or reliability.
It is.
When water cooling started (aquarium pumps, aquarium fittings, card heater matrix radiators, small-batch or DIY blocks) it wasn't all pretty metal fittings. It wasn't as pretty, but it was much more interesting, and it still worked.
The rot set in when windowed PC cases became the norm.
Is hardline tubing more effective than flexible tubing?
Does individually sleaving every cable make the computer work any better?
Doers lighting the case up like a Christmas tree do anything useful?
